주요 콘텐츠로 건너뛰기
HP Pavilion 14-cf0014dx Motherboard Replacement
필요한 것
  1. HP Pavilion 14-cf0014dx Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Motherboard Replacement: 2 단계, 이미지 1/1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Motherboard Replacement, Battery: 3 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Motherboard Replacement, Daughterboard: 5 단계, 이미지 1/1
    • Remove the two 6.7 mm screws with a Phillips #0 screwdriver.
  6. HP Pavilion 14-cf0014dx Motherboard Replacement: 6 단계, 이미지 1/2 HP Pavilion 14-cf0014dx Motherboard Replacement: 6 단계, 이미지 2/2
    • Unlock the ZIF connector with the tip of the spudger.
    • Remove the ribbon cable.
  7. HP Pavilion 14-cf0014dx Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the daughterboard with a pair of tweezers.
  8. HP Pavilion 14-cf0014dx Motherboard Replacement, Motherboard: 8 단계, 이미지 1/2 HP Pavilion 14-cf0014dx Motherboard Replacement, Motherboard: 8 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the single screw securing the SSD to the motherboard.
  9. HP Pavilion 14-cf0014dx Motherboard Replacement: 9 단계, 이미지 1/3 HP Pavilion 14-cf0014dx Motherboard Replacement: 9 단계, 이미지 2/3 HP Pavilion 14-cf0014dx Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the two 4.2 mm screws with a Phillips #0 screwdriver.
    • Use a spudger to disconnect the fan connector from the motherboard.
    • Remove the fan from the laptop.
  10. HP Pavilion 14-cf0014dx Motherboard Replacement: 10 단계, 이미지 1/2 HP Pavilion 14-cf0014dx Motherboard Replacement: 10 단계, 이미지 2/2
  11. HP Pavilion 14-cf0014dx Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the sliding cable connector with a pair of tweezers.
    • Pull from the white plastic tab and not the cables to avoid ripping them.
  12. HP Pavilion 14-cf0014dx Motherboard Replacement: 12 단계, 이미지 1/3 HP Pavilion 14-cf0014dx Motherboard Replacement: 12 단계, 이미지 2/3 HP Pavilion 14-cf0014dx Motherboard Replacement: 12 단계, 이미지 3/3
    • Remove the 4.2 mm screw with your Phillips #0 screwdriver securing the Wi-Fi card.
    • Use tweezers to detach the coaxial cables from the Wi-Fi card.
    • Hold the tweezers closer to the metal pin to avoid ripping the cable and damaging the connector when removing the clip.
  13. HP Pavilion 14-cf0014dx Motherboard Replacement: 13 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 2.5 mm screws from the motherboard.
  14. HP Pavilion 14-cf0014dx Motherboard Replacement: 14 단계, 이미지 1/3 HP Pavilion 14-cf0014dx Motherboard Replacement: 14 단계, 이미지 2/3 HP Pavilion 14-cf0014dx Motherboard Replacement: 14 단계, 이미지 3/3
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • Do not separate the metal clamps (holding the chip) too much to avoid bending them.
    • The RAM stick will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  15. HP Pavilion 14-cf0014dx Motherboard Replacement: 15 단계, 이미지 1/2 HP Pavilion 14-cf0014dx Motherboard Replacement: 15 단계, 이미지 2/2
    • Unlock the ZIF connectors with a pair of tweezers.
    • Remove the ribbon cables by the blue tab.
  16. HP Pavilion 14-cf0014dx Motherboard Replacement: 16 단계, 이미지 1/1
    • Remove the motherboard from the device.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Zion Hooper
회원 가입일: 02/08/24
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 25
전체 시간: 145
