주요 콘텐츠로 건너뛰기
HP Pavilion 14-n018us Display Assembly Replacement
필요한 것
  1. HP Pavilion 14-n018us Display Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 14-n018us Display Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Prior to removing the base plate, the battery must be removed.
    • Press the two tabs on the back of the laptop inward to release the battery.
    • Pull the battery straight out slowly and firmly.
  2. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: 2 단계, 이미지 3개 중 1개 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: 2 단계, 이미지 3개 중 2개 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: 2 단계, 이미지 3개 중 3개
    • Insert a plastic spudger into the groove around the laptop screen and gently loosen the plastic bezel away from the display.
    • Use the plastic spudger and loosen the display away from the back of the screen.
    • Continue to use the spudger to detach the small plastic detents holding the screen in place.
    • Disconnect the display cable and remove the screen.
  3. HP Pavilion 14-n018us Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • The screen can now be reassembled!
결론
작성자
2다른 기여자 명과 함께
Michael Hollister
회원 가입일: 10/01/21
253 평판
안내서 3개를 작성함
Casper College, Team 1-1, Lareau Fall 2021 Casper College, Team 1-1, Lareau Fall 2021 회원
CASC-LAREAU-F21S1G1
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 223
