주요 콘텐츠로 건너뛰기
HP Pavilion 14-n018us Hard Drive Replacement
필요한 것
  1. HP Pavilion 14-n018us Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 HP Pavilion 14-n018us Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 HP Pavilion 14-n018us Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • Start by flipping the computer, so that the bottom is facing up.
    • Using a Phillips #00 screwdriver, remove all of the 6.9 mm screws on the back cover.
    • Run an iFixit opening tool along the edges of the back cover to disconnect all the plastic hooks.
    • Remove the back cover.
  2. HP Pavilion 14-n018us Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 14-n018us Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Detach and remove the hard drive.
결론
작성자
3다른 기여자 명과 함께
Briley Reichenbach
회원 가입일: 09/27/21
85 평판
안내서 1개를 작성함
Casper College, Team 1-1, Lareau Fall 2021 Casper College, Team 1-1, Lareau Fall 2021 회원
CASC-LAREAU-F21S1G1
3 회원들
안내서 4개를 작성함
댓글 2개
There are so many parts connected to the back cover, you can't just take out the screws and pry it off you will ruin your laptop.
I've used iFixit plenty of times and never had an issue so I assumed it was safe to follow this guide.
For example the hard drive, webcam, wifi card, and charging port are all connected to the back cover.
Joe - 답글
DO NOT FOLLOW THIS GUIDE!!!!
It is incorrect, this laptop is meant to be taken appart from the top. You have to remove the keyboard and then work your way down. Follow this guide instead:
https://www.myfixguide.com/manual/hp-pav...
Bart van Netburg - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 386
