주요 콘텐츠로 건너뛰기
HP Pavilion 14-n018us RAM Replacement
필요한 것
  1. HP Pavilion 14-n018us RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 14-n018us RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Prior to removing the base plate, the battery must be removed.
    • Press the two tabs on the back of the laptop inward to release the battery.
    • Pull the battery straight out slowly and firmly.
  2. HP Pavilion 14-n018us RAM Replacement, Memory Module: 2 단계, 이미지 2개 중 1개 HP Pavilion 14-n018us RAM Replacement, Memory Module: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, unscrew the two 6.98 mm captive screws on the black cover on the bottom of the laptop.
    • Remove the cover.
  3. HP Pavilion 14-n018us RAM Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 14-n018us RAM Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 14-n018us RAM Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Push outwards on the two retaining clips on either side of each RAM chip to release the chips.
    • Use a pair of ESD-safe tweezers to gently slide the two memory modules out from the assembly.
    • If you don't have a suitable pair of tweezers, it's okay to use your fingers to remove the RAM chips. Just be sure to handle the chips by their edges, as skin contact on the faces of the chips can damage them.
결론
작성자
4다른 기여자 명과 함께
Michael Hollister
회원 가입일: 10/01/21
253 평판
안내서 3개를 작성함
Casper College, Team 1-1, Lareau Fall 2021 Casper College, Team 1-1, Lareau Fall 2021 회원
CASC-LAREAU-F21S1G1
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 161
