주요 콘텐츠로 건너뛰기
HP Pavilion 14-q020nr Battery and Speakers Replacement
필요한 것
  1. HP Pavilion 14-q020nr Battery and Speakers Replacement, Keyboard & Touchpad Panel: 1 단계, 이미지 1/2 HP Pavilion 14-q020nr Battery and Speakers Replacement, Keyboard & Touchpad Panel: 1 단계, 이미지 2/2
    • Turn the laptop over.
    • Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
  2. HP Pavilion 14-q020nr Battery and Speakers Replacement: 2 단계, 이미지 1/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 2 단계, 이미지 2/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 2 단계, 이미지 3/3
    • Pry off the four rubber bumpers, located at the top corners and center of the back panel, off with a pair of tweezers.
    • Bumpers are delicate and can be easily ripped.
    • Unscrew the four 3mm screws under the bumpers using a Phillips Head 1 screwdriver.
  3. HP Pavilion 14-q020nr Battery and Speakers Replacement: 3 단계, 이미지 1/2 HP Pavilion 14-q020nr Battery and Speakers Replacement: 3 단계, 이미지 2/2
    • Flip the laptop right side up and open the clamshell.
    • Starting at the bottom right corner, slide the opening tool into the crevice between the blue and silver panels.
    • Carefully pry the top casing up around the edges, moving counterclockwise.
    • Keep the tool steady throughout, as prying in a rough manner can break the casing.
    • You will hear audible clicking sounds as the clips connecting the two halves disconnect from each other.
  4. HP Pavilion 14-q020nr Battery and Speakers Replacement: 4 단계, 이미지 1/1
    • Close the laptop and orient it on its side (clamshell hinge up), carefully holding it steady to ensure its safety.
    • Insert the opening tool inside of the hinge and pry with an even amount of force to disconnect the keyboard panel from the fan grate.
  5. HP Pavilion 14-q020nr Battery and Speakers Replacement: 5 단계, 이미지 1/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 5 단계, 이미지 2/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 5 단계, 이미지 3/3
    • Reorient the laptop in an upright fashion and open the clamshell.
    • If needed, continue to pry the silver keyboard panel from the rest of the hardware with minimal force.
    • Slowly slide the silver keyboard panel towards you while lifting gently to separate the halves.
    • The panel is still connected by a series of delicate connectors glued to the mainframe, so do not pull the panel right off.
  6. HP Pavilion 14-q020nr Battery and Speakers Replacement: 6 단계, 이미지 1/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 6 단계, 이미지 2/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 6 단계, 이미지 3/3
    • While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
    • With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
    • Unpeel the connector ribbon from its position on the motherboard.
  7. HP Pavilion 14-q020nr Battery and Speakers Replacement: 7 단계, 이미지 1/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 7 단계, 이미지 2/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 7 단계, 이미지 3/3
    • With your finger, flip up the white clasp that connects the larger keyboard connector to the motherboard, releasing the connector ribbon.
    • Gently pull the connector ribbon from the clasp.
  8. HP Pavilion 14-q020nr Battery and Speakers Replacement: 8 단계, 이미지 1/1
    • Lift the keyboard panel up and away from the CPU, completely revealing the mainframe.
  9. HP Pavilion 14-q020nr Battery and Speakers Replacement, Battery and Speakers: 9 단계, 이미지 1/1
    • With the internal hardware exposed, disconnect the battery cable from the motherboard.
    • If tightly fastened, gently wiggle the plug out of the jack.
  10. HP Pavilion 14-q020nr Battery and Speakers Replacement: 10 단계, 이미지 1/1
    • Remove the three 4mm screws around the perimeter of the battery pack with a Phillips Head 1 screwdriver.
  11. HP Pavilion 14-q020nr Battery and Speakers Replacement: 11 단계, 이미지 1/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 11 단계, 이미지 2/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 11 단계, 이미지 3/3
    • Flip up the two white clasps that hold the connector ribbon to the battery to release the ribbon.
    • Remove the 'motherboard to USB board' connector ribbon from its place.
  12. HP Pavilion 14-q020nr Battery and Speakers Replacement: 12 단계, 이미지 1/1
    • Detach the speaker cable from its fastener on the motherboard by pulling it out with your fingers or using a spudger.
  13. HP Pavilion 14-q020nr Battery and Speakers Replacement: 13 단계, 이미지 1/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 13 단계, 이미지 2/3 HP Pavilion 14-q020nr Battery and Speakers Replacement: 13 단계, 이미지 3/3
    • Using your fingers, gently pry out the two L-shaped speaker panels from between the external casing and battery pack.
    • Be sure to apply an evenly distributed upwards force on the speaker when lifting it out
    • Both speaker components (located adjacent to each other) will remain connected by a red cable after removal
  14. HP Pavilion 14-q020nr Battery and Speakers Replacement: 14 단계, 이미지 1/1
    • Lift out battery pack.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Danica Dunville
회원 가입일: 09/11/17
349 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team S2-G2, Bruce Fall 2017 CSU Fullerton, Team S2-G2, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G2
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you for your instructions!!! HP and Chromebook sites had nothing!!! Sure they had instructions but nothing regarding how to remove the battery. The only instruction read- -remove battery!!!! Drrrrrr
Liza Bonsall - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 352
