소개
The motherboard contains multiple important internal components, such as the SSD card and the Wi-Fi card.
This guide will illustrate the prerequisite removal of the keyboard panel and then the battery pack, revealing the motherboard. Multiple screws will be removed followed by lifting the motherboard up and out of the internal casing.
필요한 것
Turn the laptop over.
Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
Unpeel the connector ribbon from its position on the motherboard.
With the internal hardware exposed, disconnect the battery cable from the motherboard.
If tightly fastened, gently wiggle the plug out of the jack.
Remove the two Wi-Fi antenna cables that are attached to the Wi-Fi card by pulling them up.
