주요 콘텐츠로 건너뛰기
HP Pavilion 14-q020nr Screen Replacement
필요한 것
  1. HP Pavilion 14-q020nr Screen Replacement, Screen: 1 단계, 이미지 1/1
    • With the laptop facing you, open the clamshell. Be sure to turn the power off using a long press before beginning.
    • Remove the screw covers on both sides of the screen bezel by sliding a metal spudger into the crevice and gently peeling the cover away.
    • If the laptop turns on at any point during the repair, quickly turn it off with a long press
  2. HP Pavilion 14-q020nr Screen Replacement: 2 단계, 이미지 1/1
    • Remove both 4mm screws using a Phillips Head 1 screwdriver
  3. HP Pavilion 14-q020nr Screen Replacement: 3 단계, 이미지 1/3 HP Pavilion 14-q020nr Screen Replacement: 3 단계, 이미지 2/3 HP Pavilion 14-q020nr Screen Replacement: 3 단계, 이미지 3/3
    • Snap off the screen bezel by prying with your fingers in between the bezel and the screen.
    • Continue around the screen, gently prying and lifting.
    • You will hear a series of audible clicks as the bezel disconnects from the other hardware.
  4. HP Pavilion 14-q020nr Screen Replacement: 4 단계, 이미지 1/1
    • Carefully loosen the bottom bezel. Eventually it will snap free from the rest of the clamshell.
    • Pull hinge up and forward to detach it from the Chromebook. The bezel and hinge cover will remain attached.
  5. HP Pavilion 14-q020nr Screen Replacement: 5 단계, 이미지 1/2 HP Pavilion 14-q020nr Screen Replacement: 5 단계, 이미지 2/2
    • Remove the four 4mm screws within the metal tabs on the top and bottom of the screen using a Phillips Head 1 screwdriver.
  6. HP Pavilion 14-q020nr Screen Replacement: 6 단계, 이미지 1/3 HP Pavilion 14-q020nr Screen Replacement: 6 단계, 이미지 2/3 HP Pavilion 14-q020nr Screen Replacement: 6 단계, 이미지 3/3
    • Gently pry the metal tabs off of the screen assembly while holding the screen to unlock them.
    • Grab the screen by its unlocked tabs and tilt it down and away from the screen assembly, laying it down.
    • The new screen may scratch, to avoid this put a cloth down on the keyboard before laying down the screen.
  7. HP Pavilion 14-q020nr Screen Replacement: 7 단계, 이미지 1/2 HP Pavilion 14-q020nr Screen Replacement: 7 단계, 이미지 2/2
    • Peel off the barcode sticker to reveal the screen connector plug.
  8. HP Pavilion 14-q020nr Screen Replacement: 8 단계, 이미지 1/3 HP Pavilion 14-q020nr Screen Replacement: 8 단계, 이미지 2/3 HP Pavilion 14-q020nr Screen Replacement: 8 단계, 이미지 3/3
    • Slide the connector out from its plug on the screen using your fingers to completely disconnect the screen.
    • Using your fingers, slide the connector out from its plug attached to the screen to completely disconnect the old screen panel
결론
Jenell Chase
회원 가입일: 09/11/17
210 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G2, Bruce Fall 2017 CSU Fullerton, Team S2-G2, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G2
3 회원들
안내서 6개 작성하였습니다
댓글 4개
Where did you find a replacement screen?
Grant McPherson - 답글
We are only showing how to replace the screen, we did not actually purchase a new screen for this guide.
Samantha Esqueda -
i have a multi layered line going down the middle of my screen how would i go about fixing something like that?
aaron kremer - 답글
Sorry, we are only knowledgeable on how to replace the screen, not on the issues.
Samantha Esqueda - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 459
