메인 콘텐츠로 스킵하기
소개
If the hard drive in your system failed or you just want to replace the drive with a larger drive or an SSD, this guide will show you how to access the hard drive for replacement.
Guide notes
  • Sort your screws. There are a lot and multiple lengths are used.
  • Hard drive replacement requires partial disassembly. If you are unsure you can do this repair, have it done by someone who can do it.
  • Hard drive replacement is unnecessarily complicated on this laptop.
  • To see if you will need assistance doing this repair, read this guide before opening the laptop.
  • This laptop can accept 7mm and 9.5mm hard drives. Use the 9.5mm bumpers on both drive thicknesses if this is what your system shipped with.
    • If your system shipped with a 7mm drive and you are installing a 9.5mm drive, you will need to purchase taller bumpers.
  • Partially reassemble the computer for testing. Complete disassembly is required to correct reassembly mistakes.
부품
  1. Shut the laptop down until it is fully hibernated or powered off. Do  not remove power until both lights on the side turn off. Shut the laptop down until it is fully hibernated or powered off. Do  not remove power until both lights on the side turn off. Shut the laptop down until it is fully hibernated or powered off. Do  not remove power until both lights on the side turn off.
    • Shut the laptop down until it is fully hibernated or powered off. Do not remove power until both lights on the side turn off.
  2. Once the computer is off, remove the battery. Pull the locking tab to the unlocked position. Once the computer is off, remove the battery. Pull the locking tab to the unlocked position. Once the computer is off, remove the battery. Pull the locking tab to the unlocked position.
    • Once the computer is off, remove the battery. Pull the locking tab to the unlocked position.
  3. Remove the battery. To do this, pull the battery forward and remove it from the laptop. Remove the battery. To do this, pull the battery forward and remove it from the laptop.
    • Remove the battery. To do this, pull the battery forward and remove it from the laptop.
  4. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
  5. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  6. Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • This screw is hidden by a stick on cover. If lost, this is only cosmetic.
    • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
  7. If you want to reuse the original pads, stick them to the hinge caps. This will preserve the adhesive. Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver. Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
    • If you want to reuse the original pads, stick them to the hinge caps. This will preserve the adhesive.
    • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
    • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
  8. The system used in the guide only came with one screw. If yours came with more then one, sort your screws accordingly.
    • The system used in the guide only came with one screw. If yours came with more then one, sort your screws accordingly.
    • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #00 or #000 screwdriver.
  9. Do not remove the palmrest. The power button is still connected and may result in power button or motherboard damage. If you are having trouble removing the palmrest, use a guitar pick to aid disassembly. Use a plastic opening tool to remove the palmrest. Do this for all 3 sides and disconnect the keyboard and trackpad connectors. Flip the black plastic tabs on the connectors up and remove the cables.
    • Do not remove the palmrest. The power button is still connected and may result in power button or motherboard damage.
    • If you are having trouble removing the palmrest, use a guitar pick to aid disassembly.
    • Use a plastic opening tool to remove the palmrest. Do this for all 3 sides and disconnect the keyboard and trackpad connectors. Flip the black plastic tabs on the connectors up and remove the cables.
    • Once the keyboard and trackpad are disconnected, loosen the final part of the palmrest. Use a pry tool as an aid if needed.
  10. With the keyboard and trackpad disconnected, lay the palmrest out so the power button flat flex can be accessed. Disconnect it the same way as the keyboard and trackpad. Once the power button is disconnected, set the palmrest aside. Once the power button is disconnected, set the palmrest aside.
    • With the keyboard and trackpad disconnected, lay the palmrest out so the power button flat flex can be accessed. Disconnect it the same way as the keyboard and trackpad.
    • Once the power button is disconnected, set the palmrest aside.
  11. If this guide is used as a prerequisite, the hard drive may not need to be removed. The I/O daugherboard can be removed if it is in the way. Disconnect the flat flex cable over the hard drive. To do this, lift the black locking tab up and remove the cable from the ZIF socket.
    • If this guide is used as a prerequisite, the hard drive may not need to be removed.
    • The I/O daugherboard can be removed if it is in the way.
    • Disconnect the flat flex cable over the hard drive. To do this, lift the black locking tab up and remove the cable from the ZIF socket.
    • To remove the hard drive, tilt it forward starting with the SATA interface. Once it is removed, set it aside as shown.
    • Disconnnect the drive cable. Wiggle the cable off until it is released. Do not force the cable off of the old drive. It may be slightly more difficult on a system that has never been serviced.
  12. If your hard drive has a plastic sticker over the PCB and an SSD is installed, put this in the chassis in case a traditional hard drive is installed later. If your drive has a plastic sticker over the PCB, transfer this to the new drive. Do this BEFORE installation.
    • If your hard drive has a plastic sticker over the PCB and an SSD is installed, put this in the chassis in case a traditional hard drive is installed later.
    • If your drive has a plastic sticker over the PCB, transfer this to the new drive. Do this BEFORE installation.
    • Remove the drive bumpers from the old drive. Transfer these to the new hard drive.
결론
Once tested and reassembled, you will need to reinstall the operating system. This is not covered in this guide.
다른 21명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 2009년 11월 10일
48,557 평판
안내서 39개 작성하였습니다
Master Techs Master Techs 회원
Community
286 회원들
안내서 811개 작성하였습니다
Some hp pavilions you need to detach the keyboard first, then, and only then, can you access the screws that hold the palmrest!
lifeat46hol - 답글
This isn't the case on the P series. The keyboard is welded in with plastic so the top piece and keyboard is a singular component.
Nick -
Thanks, Nick. Great guide, took me about 20 mins to get this done.
Maarten Merken - 답글
That’s good to know. I said 2 hours to cover for users who will take a little longer to complete the repair. The difficulty also reflects on that.
Nick -
Dear Nick,
Thank you for the info. My Wife’s laptop is a slightly different version but I was able to install a SSD today. What a nightmare! I’ve never known a laptop to be so difficult to upgrade.
Cheers!
Andy
Andy Ray - 답글
댓글 쓰기
조회 통계:
지난 24시간: 47
지난 7일: 531
지난 30일: 2,086
전체 시간: 43,389
