주요 콘텐츠로 건너뛰기
HP Pavilion 15 P Series Motherboard Replacement
필요한 것
  1. HP Pavilion 15 P Series Motherboard Replacement, Shutdown Laptop: 1 단계, 이미지 1개 중 1개
    • Before working on the laptop, make sure it is shut down.
  2. HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: 2 단계, 이미지 3개 중 1개 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: 2 단계, 이미지 3개 중 2개 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: 2 단계, 이미지 3개 중 3개
    • Pull the locking tab to the right showing a unlocked symbol.
    • Then pull the release tab to the left, releasing the battery.
    • Lift the battery out of its connection.
  3. HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: 3 단계, 이미지 2개 중 1개 HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: 3 단계, 이미지 2개 중 2개
    • Unscrew the single Phillips #0 screw that holds the optical drive in place.
    • Using a spudger push the optical drive out.
    • Pull the optical drive completely out and set it to the side.
  4. HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: 4 단계, 이미지 3개 중 1개 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: 4 단계, 이미지 3개 중 2개 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: 4 단계, 이미지 3개 중 3개
    • Using a spudger, pry up the rubber cap.
    • Remove the single screw underneath the cap.
    • Slightly lift up on the marked section of the hinge cap. Pull away from the computer to release the cap.
    • Remove the hinge screw.
    • Repeat all steps on the other side.
  5. HP Pavilion 15 P Series Motherboard Replacement, Remove Bottom Screws.: 5 단계, 이미지 1개 중 1개
    • Remove each of the highlighted screws.
    • Note, this screw is sometimes covered by a cap.
    • Remove the silver pan head crew in the optical drive bay.
  6. HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: 6 단계, 이미지 3개 중 1개 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: 6 단계, 이미지 3개 중 2개 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: 6 단계, 이미지 3개 중 3개
    • Flip your computer back over and open the display. Using a sputter, opening tool, guitar pick, or card pry up on the top case between the frame and itself.
    • Follow all the way around the top case gently, until the keyboard is able to be lifted freely.
    • NOTE* Do not lift the keyboard off until the next step in which we pull the ribbon cable connections.
    • Using your spudger, or prying tool lift the releases for each ribbon cable. *Be cautious when removing and handling ribbon cables as they are very fragile.
    • Lastly, remove the last two ribbon cables located at the top of the keyboard.
  7. HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: 7 단계, 이미지 3개 중 1개 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: 7 단계, 이미지 3개 중 2개 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: 7 단계, 이미지 3개 중 3개
    • Remove each cable and connection to the logic board.
    • Next, remove the screws holding the motherboard to the bottom case.
    • There may be a screw in this area, there was not in the computer I worked on.
    • Remove the screw holding the wifi card in place. Pull the wifi card out.
  8. HP Pavilion 15 P Series Motherboard Replacement, Finish Removing the Mother Board: 8 단계, 이미지 1개 중 1개
    • The hardest connection to remove, this is the cable to the AC/DC power port. Remove it by pulling the outside edges of the connector and wiggling gently.
  9. HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: 9 단계, 이미지 2개 중 1개 HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: 9 단계, 이미지 2개 중 2개
    • Remove the fan by disconnecting the white pin connector and then removing the only Phillips crew holding the fan in place.
    • Now you're ready to put the new logic board in!
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
help
회원 가입일: 07/24/14
494 평판
안내서 1개를 작성함
Out of a Jam Solutions Out of a Jam Solutions 회원
Business
2 회원들
안내서 3개를 작성함
3가이드 댓글
Thanks for this guide. Apparently the RAM is on the underside of the logic board?
I have a HP 15-P189NA which could do with a RAM upgrade.
Douglas Bateman - 답글
Das Modell 15-P151NG ist etwas anders, hilft trotzdem die Anleitung.
Alex Barblexi - 답글
Ich wäre an dem defekten Mainboard interessiert.
Bernd Dreyer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 123
전체 시간: 17,690
