주요 콘텐츠로 건너뛰기
HP Pavilion 15 dyl1087nr Screen Replacement
필요한 것
  1. HP Pavilion 15 dyl1087nr Screen Replacement, Laptop Screen: 1 단계, 이미지 1/3 HP Pavilion 15 dyl1087nr Screen Replacement, Laptop Screen: 1 단계, 이미지 2/3 HP Pavilion 15 dyl1087nr Screen Replacement, Laptop Screen: 1 단계, 이미지 3/3
    • Open the laptop so the screen is in an upright position.
    • Use a spudger on the underside of the bezel to release the clips securing it to the screen assembly.
    • Work your way around the entire bezel until the bezel is free.
  2. HP Pavilion 15 dyl1087nr Screen Replacement: 2 단계, 이미지 1/1
    • Remove the bezel and set it aside to reveal the laptop screen assembly interior.
    • You will need the bezel for reassembly.
  3. HP Pavilion 15 dyl1087nr Screen Replacement: 3 단계, 이미지 1/3 HP Pavilion 15 dyl1087nr Screen Replacement: 3 단계, 이미지 2/3 HP Pavilion 15 dyl1087nr Screen Replacement: 3 단계, 이미지 3/3
    • Use tweezers to remove the double-sided tape underneath the four corners of the display screen.
    • If you tear the tape, it is okay, it will just be moderately more challenging to pull the display screen off from the laptop.
  4. HP Pavilion 15 dyl1087nr Screen Replacement: 4 단계, 이미지 1/2 HP Pavilion 15 dyl1087nr Screen Replacement: 4 단계, 이미지 2/2
    • Flip the display screen over facedown to reveal the tape connecting the screen to the rest of the computer.
  5. HP Pavilion 15 dyl1087nr Screen Replacement: 5 단계, 이미지 1/3 HP Pavilion 15 dyl1087nr Screen Replacement: 5 단계, 이미지 2/3 HP Pavilion 15 dyl1087nr Screen Replacement: 5 단계, 이미지 3/3
    • Remove the tape covering the display cable connector.
    • Use your spudger to detach the display cable connector. First, gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
    • Grip the cable and buckle together and insert the connector fully into its socket.
    • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
    • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
  6. HP Pavilion 15 dyl1087nr Screen Replacement: 6 단계, 이미지 1/1
    • Remove the old LCD screen and replace it with your new display screen.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Rick Tan
회원 가입일: 03/05/24
133 평판
안내서 1개 작성함
CSU Los Angeles, Team 7-9, Grodsky Spring 2024 CSU Los Angeles, Team 7-9, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S7G9
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 11
전체 시간: 41
