주요 콘텐츠로 건너뛰기
HP Pavilion 15-AB153NR Bottom Case Cover Replacement
필요한 것
  1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 3 단계, 이미지 2개 중 2개
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
  4. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, CD/DVD Drive: 4 단계, 이미지 1개 중 1개
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  5. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  6. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the drive out from the right side of the device.
  7. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, Bottom Case Cover: 7 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
  8. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the corner covers off of the computer using a prying tool.
  9. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
  10. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
  11. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 11 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the two 2mm screws.
  12. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 12 단계, 이미지 3개 중 3개
    • Use prying tools to pry the covers off of the screwholes.
    • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
  13. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 13 단계, 이미지 1개 중 1개
    • Be mindful of sharp edges on computer while using prying tools.
    • Flip computer over and open so that the screen is facing you.
    • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
    • Continue down all sides and corners of the device.
  14. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 14 단계, 이미지 2개 중 2개
    • Flip laptop back over so that the bottom is facing up
    • After all sides are loosened, remove the back panel from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nicole Vachon
회원 가입일: 03/21/19
944 평판
안내서 7개를 작성함
UMass Dartmouth, Team S1-G4, Simcock Spring 2019 UMass Dartmouth, Team S1-G4, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G4
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 29
전체 시간: 1,252
