주요 콘텐츠로 건너뛰기
HP Pavilion 15-AB153NR CD/DVD Drive Replacement
필요한 것
  1. HP Pavilion 15-AB153NR CD/DVD Drive Replacement, CD/DVD Drive: 1 단계, 이미지 1개 중 1개
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  2. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  3. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-AB153NR CD/DVD Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the drive out from the right side of the device.
결론
작성자
6다른 기여자 명과 함께
Nicole Vachon
회원 가입일: 03/21/19
944 평판
안내서 7개를 작성함
UMass Dartmouth, Team S1-G4, Simcock Spring 2019 UMass Dartmouth, Team S1-G4, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G4
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 35
전체 시간: 975
