주요 콘텐츠로 건너뛰기
HP Pavilion 15-ab165us Battery and Back Cover Replacement
필요한 것
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: 1 단계, 이미지 2개 중 2개
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Battery and Back Cover Replacement: 7 단계, 이미지 2개 중 2개
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: 8 단계, 이미지 1개 중 1개
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Dillon Hubble
회원 가입일: 10/20/17
653 평판
안내서 3개를 작성함
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 회원
UWT-ROSE-F17S1G2
5 회원들
안내서 14개를 작성함
댓글 한 개
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 76
전체 시간: 66,479
