주요 콘텐츠로 건너뛰기
HP Pavilion 15-ab165us Motherboard Replacement
필요한 것
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: 1 단계, 이미지 2개 중 2개
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: 13 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: 15 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 15 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: 17 단계, 이미지 1개 중 1개
  18. HP Pavilion 15-ab165us Motherboard Replacement: 18 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: 19 단계, 이미지 1개 중 1개
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: 20 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: 21 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Motherboard Replacement: 21 단계, 이미지 2개 중 2개
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dillon Hubble
회원 가입일: 10/20/17
653 평판
안내서 3개를 작성함
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 회원
UWT-ROSE-F17S1G2
5 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 11
지난 30일: 29
전체 시간: 1,597
