주요 콘텐츠로 건너뛰기
HP Pavilion 15-ab165us Wi-Fi Card Replacement
필요한 것
  1. HP Pavilion 15-ab165us Wi-Fi Card Replacement, Battery and Back Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Wi-Fi Card Replacement, Battery and Back Cover: 1 단계, 이미지 2개 중 2개
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 15-ab165us Wi-Fi Card Replacement: 7 단계, 이미지 2개 중 2개
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 8 단계, 이미지 1개 중 1개
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Wi-Fi Card Replacement, Wi-Fi Card: 9 단계, 이미지 1개 중 1개
    • Locate the Wi-Fi card.
  10. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the cable from the clips and use the spudger to disconnect the wire from the Wi-Fi card.
  11. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 11 단계, 이미지 1개 중 1개
    • Use the Phillips #1 screwdriver to remove the single 4mm screw.
  12. HP Pavilion 15-ab165us Wi-Fi Card Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the Wi-Fi card up and out.
결론
작성자
3다른 기여자 명과 함께
Grace Chapek
회원 가입일: 10/18/17
101 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 회원
UWT-ROSE-F17S1G2
5 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 22
전체 시간: 539
