소개
The CMOS Battery is responsible for keeping your time clock correct on the device, even after the main battery runs out of juice. If you are experiencing issues with your time clock resetting, then this guide will help you replace the battery.
필요한 것
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
이 단계에 사용된 도구:Tweezers$4.99
Use long nose tweezers to reach under battery and lift up.
다른 한 분이 해당 안내서를 완성하였습니다.
