주요 콘텐츠로 건너뛰기
HP Pavilion 15-ab243cl RAM Stick Replacement
필요한 것
  1. HP Pavilion 15-ab243cl RAM Stick Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery lock tab toward the center of the battery to the unlock position.
  2. HP Pavilion 15-ab243cl RAM Stick Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl RAM Stick Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the battery release switch to the right until the battery pops out.
  3. HP Pavilion 15-ab243cl RAM Stick Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement: 3 단계, 이미지 2개 중 2개
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
  4. HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: 4 단계, 이미지 3개 중 3개
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
  5. HP Pavilion 15-ab243cl RAM Stick Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl RAM Stick Replacement: 5 단계, 이미지 3개 중 3개
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
  6. HP Pavilion 15-ab243cl RAM Stick Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement: 6 단계, 이미지 2개 중 2개
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
  7. HP Pavilion 15-ab243cl RAM Stick Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl RAM Stick Replacement: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
  8. HP Pavilion 15-ab243cl RAM Stick Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl RAM Stick Replacement: 8 단계, 이미지 3개 중 3개
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
  9. HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: 9 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: 9 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: 9 단계, 이미지 3개 중 3개
    • Locate the RAM stick, will be next to hard drive. Unclip the two silver retainers on each side.
  10. HP Pavilion 15-ab243cl RAM Stick Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion 15-ab243cl RAM Stick Replacement: 10 단계, 이미지 2개 중 2개
    • The card will pop up when silver retainers are released. The card is ready to remove, pull straight out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alexander Bicigo
회원 가입일: 02/14/18
942 평판
안내서 6개를 작성함
USF Tampa, Team S6-G3, Eyestone Spring 2018 USF Tampa, Team S6-G3, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G3
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 767
