주요 콘텐츠로 건너뛰기
HP Pavilion 15-au123cl CD Drive Replacement
필요한 것
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl CD Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl CD Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl CD Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-au123cl CD Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-au123cl CD Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: 6 단계, 이미지 1개 중 1개
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl CD Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the CD drive from the motherboard connector on the left.
결론
작성자
1다른 기여자 명과 함께
Mohammad Gardezi
회원 가입일: 10/17/17
1,420 평판
안내서 6개를 작성함
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G3
2 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 20
전체 시간: 631
