주요 콘텐츠로 건너뛰기
HP Pavilion 15-au123cl Network Card Replacement
필요한 것
  1. HP Pavilion 15-au123cl Network Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Network Card Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl Network Card Replacement: 2 단계, 이미지 2개 중 2개
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Network Card Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl Network Card Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Network Card Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl Network Card Replacement: 4 단계, 이미지 2개 중 2개
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Network Card Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-au123cl Network Card Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-au123cl Network Card Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Network Card Replacement, Network Card: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-au123cl Network Card Replacement, Network Card: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-au123cl Network Card Replacement, Network Card: 6 단계, 이미지 3개 중 3개
    • The network card is located at the top left corner of the motherboard.
    • Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
  7. HP Pavilion 15-au123cl Network Card Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-au123cl Network Card Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-au123cl Network Card Replacement: 7 단계, 이미지 3개 중 3개
    • Using the spudger, remove the two gold pins at the top of the network card.
    • It is recommended to gently apply a vertical force upward with the spudger.
  8. HP Pavilion 15-au123cl Network Card Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-au123cl Network Card Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-au123cl Network Card Replacement: 8 단계, 이미지 3개 중 3개
    • Lift up the network card and remove it from the motherboard connector.
결론
작성자
1다른 기여자 명과 함께
Mohammad Gardezi
회원 가입일: 10/17/17
1,420 평판
안내서 6개를 작성함
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G3
2 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 24
전체 시간: 1,699
