주요 콘텐츠로 건너뛰기
소개
By following this guide, you will be able to change the RAM sticks on your laptop. You may wish to do this if you want to upgrade the maximum RAM available or if you are noticing slowdown on your computer. You will first remove the battery before you remove the RAM.
부품
지정된 부품이 없습니다.
  1. Make sure the laptop is off and unplugged before starting.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. Using the plastic opening tool, remove the back cover of the laptop. It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
    What? I think you have have neglected to mention the DVD drawer. I believe it needs to be pulled out after removing the center screw and before removing the cover.
    Dan Enslow - 답글
    Yes, best to remove the drawer as recommended. Also there are 3 screws holding the battery, not 2.
    Lastly, pay careful attention to the orientation photo when removing the back.
    I did not have the plastic tool but used a small Teflon type kitchen spatula and it did the trick. Do not use a metal screw driver or other such tool.
    Edward Yandek - 답글
  4. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    there is a third screw on bottom left of battery (in picture above)
    Paul Behrman - 답글
  5. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. The RAM is located at the lower middle region of the motherboard. Push down on the clips on both sides of the RAM stick evenly.
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. Pull the RAM stick out of the motherboard.
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mohammad Gardezi
회원 가입일: 2017년 10월 17일
910 평판
안내서 6개 작성하였습니다
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G3
2 회원들
안내서 6개 작성하였습니다
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 525
