주요 콘텐츠로 건너뛰기
HP Pavilion 15-ay041wm Battery Replacement
  1. HP Pavilion 15-ay041wm Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Battery Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-ay041wm Battery Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-ay041wm Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rahmatullo Khudoi Nazar
회원 가입일: 01/14/20
445 평판
안내서 2개를 작성함
York University, Team S1-G2, Woodhouse Winter 2020 York University, Team S1-G2, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G2
3 회원들
안내서 4개를 작성함
2가이드 댓글
Hello, I have a similar model, HP 15-ay039wm. I purchased a replacement battery from ifixit. Original was 10.9V and description of the replacement said it was 11V, but it says 14V on the replacement. Main problem is that it won’t charge and the laptop doesn’t seem to recognize it. I’ve tried a few fixes such as power reset but have NOT updated the BIOS. Any suggestions? Thank you!
JoV - 답글
When charger cord is not plugged in to the notebook the lab top will not turn on
Terri - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,136
