주요 콘텐츠로 건너뛰기
HP Pavilion 15-ay041wm LCD Screen Replacement
필요한 것
  1. HP Pavilion 15-ay041wm LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-ay041wm LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-ay041wm LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
    • Place the laptop on a flat surface with the lid open.
  5. HP Pavilion 15-ay041wm LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull away the bezel by the inner edge starting from the side until bezel is detached from screen.
    • To avoid scratching the screen, do not use any sharp objects.
  6. HP Pavilion 15-ay041wm LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Unsnap the two hinges attached to the clam shell by pulling towards yourself and then up.
  7. HP Pavilion 15-ay041wm LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four 3mm screws that are holding the LCD panel in place.
  8. HP Pavilion 15-ay041wm LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Gently pull the screen from the hooks and place it on the keyboard.
    • The video cable is attached to the bottom of the LCD screen.
  9. HP Pavilion 15-ay041wm LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Peel the tape securing the video cable.
  10. HP Pavilion 15-ay041wm LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Gently disconnect the video cable to detach the LCD screen from the back panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Rahmatullo Khudoi Nazar
회원 가입일: 01/14/20
445 평판
안내서 2개를 작성함
York University, Team S1-G2, Woodhouse Winter 2020 York University, Team S1-G2, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G2
3 회원들
안내서 4개를 작성함
1가이드 댓글
Hi. This is my first time trying to fix a computer by myself, but I'm desperate -old lady, low fixed income & this is my only computer. Please, please help! Trying to replace LCD cable, not the screen itself from HP15-ay041wm. [Screen fading from various shades of color to white & cursor freezes. Have to keep moving/tilting screen till find the “sweet spot". Then have to keep holding onto screen w/one hand while trying to type w/other. That lasts a few moments, but it eventually starts going goofy again & I have to find its new sweet spot. Hear this seems to be pretty common w/this model.] Followed your terrific directions & removed screen & disco’d the cable from screen, but now I'm stuck & panicking. How do I get the old cable past the hinge setup, get bad cable out of the main guts of the comp & get the new cable in? I've got this thing taken apart, scared to death I'm gonna ruin the whole computer and I can't afford a new one. So grateful for your help. Thx, God bless, be safe & well!
Bernadette - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 1,785
