주요 콘텐츠로 건너뛰기
HP Pavilion 15-ay041wm RAM Replacement
필요한 것
  1. HP Pavilion 15-ay041wm RAM Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion 15-ay041wm RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-ay041wm RAM Replacement: 2 단계, 이미지 2/2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm RAM Replacement: 3 단계, 이미지 1/3 HP Pavilion 15-ay041wm RAM Replacement: 3 단계, 이미지 2/3 HP Pavilion 15-ay041wm RAM Replacement: 3 단계, 이미지 3/3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm RAM Replacement, Disc Drive: 4 단계, 이미지 1/1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm RAM Replacement: 5 단계, 이미지 1/3 HP Pavilion 15-ay041wm RAM Replacement: 5 단계, 이미지 2/3 HP Pavilion 15-ay041wm RAM Replacement: 5 단계, 이미지 3/3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm RAM Replacement, Keyboard: 6 단계, 이미지 1/3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: 6 단계, 이미지 2/3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: 6 단계, 이미지 3/3
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
  7. HP Pavilion 15-ay041wm RAM Replacement, RAM: 7 단계, 이미지 1/3 HP Pavilion 15-ay041wm RAM Replacement, RAM: 7 단계, 이미지 2/3 HP Pavilion 15-ay041wm RAM Replacement, RAM: 7 단계, 이미지 3/3
    • Orient the base of the laptop with the base facing away from you.
    • With you index finger and thumb, position your thumb underneath both latches on either side of the RAM and squeeze outwards.
    • Simultaneously, use your index finger to push the RAM sticks towards you.
    • The RAM stick will release and pop up and out.
  8. HP Pavilion 15-ay041wm RAM Replacement: 8 단계, 이미지 1/2 HP Pavilion 15-ay041wm RAM Replacement: 8 단계, 이미지 2/2
    • Repeat the same process for the top RAM stick.
    • The RAM stick will release and pop up. Pull the RAM stick out to remove it from the laptop.
결론
Carlton Makini
회원 가입일: 01/30/20
195 평판
안내서 1개 작성함
York University, Team S1-G2, Woodhouse Winter 2020 York University, Team S1-G2, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 20
전체 시간: 724
