주요 콘텐츠로 건너뛰기
HP Pavilion 15-b109wm Hard Drive Replacement
필요한 것
  1. HP Pavilion 15-b109wm Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Hard Drive Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Hard Drive Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Hard Drive Replacement: 10 단계, 이미지 3개 중 3개
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm Hard Drive Replacement, Fan: 11 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement, Fan: 11 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Hard Drive Replacement, Fan: 11 단계, 이미지 3개 중 3개
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm Hard Drive Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Hard Drive Replacement: 12 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm Hard Drive Replacement: 13 단계, 이미지 1개 중 1개
    • Carefully remove the fan from its slot.
  14. HP Pavilion 15-b109wm Hard Drive Replacement, Hard Drive: 14 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement, Hard Drive: 14 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Hard Drive Replacement, Hard Drive: 14 단계, 이미지 3개 중 3개
    • Disconnect the cables to the motherboard.
  15. HP Pavilion 15-b109wm Hard Drive Replacement: 15 단계, 이미지 2개 중 1개 HP Pavilion 15-b109wm Hard Drive Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the hard drive.
결론
To reassemble your device, follow the instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Enrico Miozzo
회원 가입일: 11/07/19
244 평판
안내서 2개를 작성함
IUPUI, Team S2-G4, Harley Fall 2019 IUPUI, Team S2-G4, Harley Fall 2019 회원
IUPUI-HARLEY-F19S2G4
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 40
전체 시간: 1,024
