주요 콘텐츠로 건너뛰기
HP Pavilion 15-b109wm Motherboard Replacement
필요한 것
  1. HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: 1 단계, 이미지 1/3 HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: 1 단계, 이미지 2/3 HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Disconnect the cables to the motherboard.
  2. HP Pavilion 15-b109wm Motherboard Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-b109wm Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the hard drive.
  3. HP Pavilion 15-b109wm Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 HP Pavilion 15-b109wm Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Unclip the WLAN cable out of its place to allow the motherboard room to move.
  4. HP Pavilion 15-b109wm Motherboard Replacement: 4 단계, 이미지 1/2 HP Pavilion 15-b109wm Motherboard Replacement: 4 단계, 이미지 2/2
    • Detach the power connector cable.
  5. HP Pavilion 15-b109wm Motherboard Replacement: 5 단계, 이미지 1/2 HP Pavilion 15-b109wm Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the motherboard from the device.
결론
To reassemble your device work in the reverse order, make sure all the screws are in their required hole before assembling the next part.
Enrico Miozzo
회원 가입일: 11/07/19
244 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G4, Harley Fall 2019 IUPUI, Team S2-G4, Harley Fall 2019 회원
IUPUI-HARLEY-F19S2G4
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 343
