주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Backplate Replacement
필요한 것
  1. HP Pavilion 15-ba003ds Backplate Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion 15-ba003ds Backplate Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Backplate Replacement, Disc Drive: 2 단계, 이미지 1/1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Backplate Replacement: 3 단계, 이미지 1/2 HP Pavilion 15-ba003ds Backplate Replacement: 3 단계, 이미지 2/2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Backplate Replacement: 4 단계, 이미지 1/2 HP Pavilion 15-ba003ds Backplate Replacement: 4 단계, 이미지 2/2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds Backplate Replacement, Backplate: 5 단계, 이미지 1/3 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: 5 단계, 이미지 2/3 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: 5 단계, 이미지 3/3
    • Use a Jimmy to pry off the black backplate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Krushnam Badami
회원 가입일: 01/14/20
342 평판
안내서 3개 작성하였습니다
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 441
