주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Charging Port Replacement
필요한 것
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: 2 단계, 이미지 3개 중 3개
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: 3 단계, 이미지 2개 중 2개
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Charging Port Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Charging Port Replacement: 4 단계, 이미지 3개 중 3개
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Charging Port Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Charging Port Replacement: 5 단계, 이미지 3개 중 3개
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: 6 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Charging Port Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Charging Port Replacement: 7 단계, 이미지 3개 중 3개
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Charging Port Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to pry off the charging port.
결론
작성자
3다른 기여자 명과 함께
LI XU
회원 가입일: 01/14/20
334 평판
안내서 2개를 작성함
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개를 작성함
댓글 한 개
how much does it cost to replace a laptop charging port
Ebele Athekame - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 38
전체 시간: 2,408
