주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Hard Drive Replacement
필요한 것
  1. HP Pavilion 15-ba003ds Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Hard Drive Replacement, Disc Drive: 2 단계, 이미지 1개 중 1개
    • Use a spudger to remove the two rubber feet next to the battery.
    • This will reveal two hidden screws.
    • Save the feet for reassembly.
  3. HP Pavilion 15-ba003ds Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove twelve 8 mm screws from the bottom of your laptop including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the disc drive from your laptop to remove it.
  5. HP Pavilion 15-ba003ds Hard Drive Replacement, Backplate: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Hard Drive Replacement, Backplate: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Hard Drive Replacement, Backplate: 5 단계, 이미지 3개 중 3개
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Hard Drive Replacement, Hard Drive: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Hard Drive Replacement, Hard Drive: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Hard Drive Replacement, Hard Drive: 6 단계, 이미지 3개 중 3개
    • Remove the data connector from the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
LI XU
회원 가입일: 01/14/20
334 평판
안내서 2개를 작성함
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 523
