주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Screen Replacement
필요한 것
  1. HP Pavilion 15-ba003ds Screen Replacement, Screen: 1 단계, 이미지 1/3 HP Pavilion 15-ba003ds Screen Replacement, Screen: 1 단계, 이미지 2/3 HP Pavilion 15-ba003ds Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
    • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
  2. HP Pavilion 15-ba003ds Screen Replacement: 2 단계, 이미지 1/3 HP Pavilion 15-ba003ds Screen Replacement: 2 단계, 이미지 2/3 HP Pavilion 15-ba003ds Screen Replacement: 2 단계, 이미지 3/3
    • Continue sliding the metal spudger to the bottom of the screen.
    • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
  3. HP Pavilion 15-ba003ds Screen Replacement: 3 단계, 이미지 1/3 HP Pavilion 15-ba003ds Screen Replacement: 3 단계, 이미지 2/3 HP Pavilion 15-ba003ds Screen Replacement: 3 단계, 이미지 3/3
    • Flip the laptop so the bottom is facing upwards.
    • Using the metal spudger, separate the plastic panel off the screen.
  4. HP Pavilion 15-ba003ds Screen Replacement: 4 단계, 이미지 1/3 HP Pavilion 15-ba003ds Screen Replacement: 4 단계, 이미지 2/3 HP Pavilion 15-ba003ds Screen Replacement: 4 단계, 이미지 3/3
    • Once the panel is separated from the screen, gently pull it off and set it aside.
    • Remove two 6mm Phillips #00 screws from the bottom of the screen.
  5. HP Pavilion 15-ba003ds Screen Replacement: 5 단계, 이미지 1/3 HP Pavilion 15-ba003ds Screen Replacement: 5 단계, 이미지 2/3 HP Pavilion 15-ba003ds Screen Replacement: 5 단계, 이미지 3/3
    • Remove two 6mm Phillips #00 screws from the top of the screen.
  6. HP Pavilion 15-ba003ds Screen Replacement: 6 단계, 이미지 1/3 HP Pavilion 15-ba003ds Screen Replacement: 6 단계, 이미지 2/3 HP Pavilion 15-ba003ds Screen Replacement: 6 단계, 이미지 3/3
    • Flip the screen down.
    • Remove the tape from over the connector.
    • Pull out the connector using your fingers.
  7. HP Pavilion 15-ba003ds Screen Replacement: 7 단계, 이미지 1/1
    • Lift the screen away from the laptop.
결론
Joseph Chia
회원 가입일: 01/14/20
355 평판
안내서 3개 작성하였습니다
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 265
