주요 콘텐츠로 건너뛰기
HP Pavilion 15-bk020wm Battery Replacement
필요한 것
  1. HP Pavilion 15-bk020wm Battery Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Battery Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 2개
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Battery Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-bk020wm Battery Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-bk020wm Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Detach the blue ZIF cable from the bottom of the laptop.
    • Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
  5. HP Pavilion 15-bk020wm Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four Phillips M2.5x4.4 screws using the Phillips 00 located along the perimeter of the battery.
  6. HP Pavilion 15-bk020wm Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the damaged battery from the laptop.
    • Insert the new battery.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hannah Paine
회원 가입일: 06/28/17
392 평판
안내서 2개를 작성함
댓글 2개
Hidden bolts are tricky to understand at first.
Riben Deguhur - 답글
can i still use my laptop without the battery (the same type of battery shown on those picture) and directly plugged in?? I've been worried since it's just stuck on a very low percentage
Shouko kazumi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 84
지난 30일: 216
전체 시간: 71,840
