주요 콘텐츠로 건너뛰기
HP Pavilion 15-bk020wm Hard Drive Replacement
필요한 것
  1. HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 2개
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-bk020wm Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-bk020wm Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Remove the hard drive from the laptop.
    • Our device did not contain a hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hannah Paine
회원 가입일: 06/28/17
392 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 46
전체 시간: 17,355
