주요 콘텐츠로 건너뛰기
HP Pavilion 15-bk020wm Keyboard Cover Replacement
필요한 것
  1. HP Pavilion 15-bk020wm Keyboard Cover Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Keyboard Cover Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 2개
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Keyboard Cover Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-bk020wm Keyboard Cover Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-bk020wm Keyboard Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Keyboard Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Meshayla Block
회원 가입일: 06/28/17
443 평판
안내서 3개를 작성함
1가이드 댓글
two questions
Where can i get these tools?
Will these instructions work for HP Notebook - 15-db0019au ?
craftcove - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 50
전체 시간: 13,998
