주요 콘텐츠로 건너뛰기
HP Pavilion 15-bk020wm Touchpad Replacement
필요한 것
  1. HP Pavilion 15-bk020wm Touchpad Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Touchpad Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 2개
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Touchpad Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-bk020wm Touchpad Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-bk020wm Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Touchpad Replacement: 3 단계, 이미지 1개 중 1개
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Touchpad Replacement, Touchpad: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Touchpad Replacement, Touchpad: 4 단계, 이미지 2개 중 2개
    • After taking the keyboard cover off of the device, flip it over and locate the purple and white cable.
    • Using the plastic opening tool, flip the ZIF connector open and detach the touchpad cable.
  5. HP Pavilion 15-bk020wm Touchpad Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-bk020wm Touchpad Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-bk020wm Touchpad Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the three screws at the bottom of the touchpad using the #00 Phillips screwdriver.
    • Life the bottom security piece off of the touchpad.
    • Unscrew the three top screws using the same #00 Phillips screwdriver.
  6. HP Pavilion 15-bk020wm Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, lift the touchpad off of the keyboard cover.
결론
작성자
1다른 기여자 명과 함께
Meshayla Block
회원 가입일: 06/28/17
437 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 34
전체 시간: 7,437
