주요 콘텐츠로 건너뛰기
HP Pavilion 15-bk020wm Touchscreen Replacement
필요한 것
  1. HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: 1 단계, 이미지 2개 중 2개
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Touchscreen Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-bk020wm Touchscreen Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-bk020wm Touchscreen Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Touchscreen Replacement: 3 단계, 이미지 1개 중 1개
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Detach the blue ZIF cable from the bottom of the laptop.
    • Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
  5. HP Pavilion 15-bk020wm Touchscreen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four Phillips M2.5x4.4 screws using the Phillips 00 located along the perimeter of the battery.
  6. HP Pavilion 15-bk020wm Touchscreen Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the damaged battery from the laptop.
    • Insert the new battery.
  7. HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: 7 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: 7 단계, 이미지 2개 중 2개
    • Detach the two cables from the motherboard.
  8. HP Pavilion 15-bk020wm Touchscreen Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew all ten screws (M2.5x4.4) using the Phillips 00 screwdriver from the motherboard. Be sure to unscrew the fan as well.
    • Lift the motherboard with the fan.
  9. HP Pavilion 15-bk020wm Touchscreen Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion 15-bk020wm Touchscreen Replacement: 9 단계, 이미지 2개 중 2개
    • Unscrew the screen from the laptop body using Phillips 00. Screw size: M2.5x4.4
  10. HP Pavilion 15-bk020wm Touchscreen Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the touchscreen hinges using the plastic opening tool to detach the screen.
    • Obtain the new touchscreen to connect to your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Meshayla Block
회원 가입일: 06/28/17
437 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 21
전체 시간: 5,705
