주요 콘텐츠로 건너뛰기
HP Pavilion 15-ca2073cl Battery Replacement
필요한 것
  1. HP Pavilion 15-ca2073cl Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Battery Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-ca2073cl Battery Replacement: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Battery Replacement, Battery: 3 단계, 이미지 1/2 HP Pavilion 15-ca2073cl Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
결론
Sirong Ren
회원 가입일: 10/04/19
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 37
전체 시간: 1,946
