소개
The HP Pavilion 15-ca2073cl motherboard is a common replacement needed for this laptop. The following guide consists of a step by step process to replace the component with moderate difficulty. Be sure to have all tools needed to complete the replacement without damaging the rest of the components.
필요한 것
Flip the laptop over.
Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
Remove the screws surrounding the motherboard using the Phillips #00 screwdriver.
Dismount the power supply ribbon cable by lifting the cable lock and pulling the cable with the flat-tipped tweezers.
Gently remove and disconnect the two display ribbon cables located at the top right corner of the moother board.
Disconnect the keyboard cable next to the power supply cable.
Disconnect the disc and hard drive cables.
