주요 콘텐츠로 건너뛰기
HP Pavilion 15-ca2073cl Motherboard Replacement
필요한 것
  1. HP Pavilion 15-ca2073cl Motherboard  Replacement, Back Cover: 1 단계, 이미지 1/1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Motherboard  Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-ca2073cl Motherboard  Replacement: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Motherboard  Replacement, Battery: 3 단계, 이미지 1/2 HP Pavilion 15-ca2073cl Motherboard  Replacement, Battery: 3 단계, 이미지 2/2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl Motherboard  Replacement, Motherboard: 4 단계, 이미지 1/2 HP Pavilion 15-ca2073cl Motherboard  Replacement, Motherboard: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the screws surrounding the motherboard using the Phillips #00 screwdriver.
    • Dismount the power supply ribbon cable by lifting the cable lock and pulling the cable with the flat-tipped tweezers.
    • Gently remove and disconnect the two display ribbon cables located at the top right corner of the moother board.
    • Disconnect the keyboard cable next to the power supply cable.
    • Disconnect the disc and hard drive cables.
  5. HP Pavilion 15-ca2073cl Motherboard  Replacement: 5 단계, 이미지 1/1
    • Using the flat-tipped tweezers, remove the cable wrapping around the left fan connecting to the mother board.
  6. HP Pavilion 15-ca2073cl Motherboard  Replacement: 6 단계, 이미지 1/1
    • Remove the three Phillips #00 screws surrounding the fans.
    • Remove the cables connecting the fans to the motherboard.
    • Gently lift the fans out of place.
  7. HP Pavilion 15-ca2073cl Motherboard  Replacement: 7 단계, 이미지 1/2 HP Pavilion 15-ca2073cl Motherboard  Replacement: 7 단계, 이미지 2/2
    • Using the spudger, begin to pry all ports connected to the motherboard away from the shell of the laptop.
    • Using the spudger, gently pry the motherboard up and out.
결론
Clarence Droze
회원 가입일: 02/20/20
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 21
전체 시간: 966
