주요 콘텐츠로 건너뛰기
HP Pavilion 15-ca2073cl RAM Replacement
필요한 것
  1. HP Pavilion 15-ca2073cl RAM Replacement, Back Cover: 1 단계, 이미지 1/1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-ca2073cl RAM Replacement: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl RAM Replacement, Battery: 3 단계, 이미지 1/2 HP Pavilion 15-ca2073cl RAM Replacement, Battery: 3 단계, 이미지 2/2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl RAM Replacement, RAM: 4 단계, 이미지 1/3 HP Pavilion 15-ca2073cl RAM Replacement, RAM: 4 단계, 이미지 2/3 HP Pavilion 15-ca2073cl RAM Replacement, RAM: 4 단계, 이미지 3/3
    • Pull the silver tabs on either side of the RAM outward.
    • Pull the RAM stick out of its slot.
  5. HP Pavilion 15-ca2073cl RAM Replacement: 5 단계, 이미지 1/3 HP Pavilion 15-ca2073cl RAM Replacement: 5 단계, 이미지 2/3 HP Pavilion 15-ca2073cl RAM Replacement: 5 단계, 이미지 3/3
    • Pull the tabs outward on either side of the second RAM stick.
결론
Alexander Burke Ott
회원 가입일: 09/20/21
90 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 262
