주요 콘텐츠로 건너뛰기
HP Pavilion 15-ca2073cl SD Card Reader Replacement
필요한 것
동영상 개요
  1. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Back Cover: 1 단계, 이미지 1/1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl SD Card Reader Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-ca2073cl SD Card Reader Replacement: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: 3 단계, 이미지 1/2 HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: 3 단계, 이미지 2/2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: 4 단계, 이미지 1/3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: 4 단계, 이미지 2/3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: 4 단계, 이미지 3/3
    • Use a spudger to flip up the retaining flap securing the ribbon cable
    • Remove the white ribbon cable from its connector.
  5. HP Pavilion 15-ca2073cl SD Card Reader Replacement: 5 단계, 이미지 1/1
    • Remove the single silver 4.3 mm screw with a Phillips #0 screwdriver.
  6. HP Pavilion 15-ca2073cl SD Card Reader Replacement: 6 단계, 이미지 1/1
    • Remove the SD card reader from the laptop.
결론
Hunter Hamilton
회원 가입일: 09/20/21
125 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 13
전체 시간: 283
