주요 콘텐츠로 건너뛰기
HP Pavilion 15-cc023cl Battery Replacement
필요한 것
  1. HP Pavilion 15-cc023cl Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion 15-cc023cl Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Battery Replacement: 2 단계, 이미지 1/1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Battery Replacement: 3 단계, 이미지 1/2 HP Pavilion 15-cc023cl Battery Replacement: 3 단계, 이미지 2/2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Battery Replacement: 4 단계, 이미지 1/2 HP Pavilion 15-cc023cl Battery Replacement: 4 단계, 이미지 2/2
    • Disconnect the port connecting the battery and the motherboard and then remove.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Stephanie Henry
회원 가입일: 10/02/18
1,077 평판
안내서 5개 작성하였습니다
댓글 2개
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - 답글
If you plan to replace it yeah, what do you even plan to replace? battery, no, harddrive, no, and im not sure about the other stuff.
Don't hurt the chickens -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 34
전체 시간: 3,848
