주요 콘텐츠로 건너뛰기
HP Pavilion 15-cd040wm Back Cover Disassembly
필요한 것
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 2개
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm Back Cover Disassembly: 2 단계, 이미지 2개 중 2개
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
    You skipped over the part where you removed the cd rom tray? I can’t figure out how to get it out without breaking it.
    Robert Jones - 답글
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-cd040wm Back Cover Disassembly: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-cd040wm Back Cover Disassembly: 3 단계, 이미지 3개 중 3개
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
    You did not describe how to remove the CD drive. It suddenly disappeared between step 2 and step 3.
    Stan - 답글
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joe Krawczyk
회원 가입일: 11/01/19
397 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G1
4 회원들
안내서 8개를 작성함
댓글 3개
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - 답글
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - 답글
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 34
지난 30일: 113
전체 시간: 9,523
