주요 콘텐츠로 건너뛰기
HP Pavilion 15-d017cl RAM Replacement
필요한 것
  1. HP Pavilion 15-d017cl RAM Replacement, Battery: 1 단계, 이미지 1/3 HP Pavilion 15-d017cl RAM Replacement, Battery: 1 단계, 이미지 2/3 HP Pavilion 15-d017cl RAM Replacement, Battery: 1 단계, 이미지 3/3
    • To unlock the top left latch, place your finger on the black latch and slide toward the center of the computer.
    • You do not need to hold this latch when removing the battery.
  2. HP Pavilion 15-d017cl RAM Replacement: 2 단계, 이미지 1/1
    • To unlock the top right latch, slide the black latch towards the center of the computer.
  3. HP Pavilion 15-d017cl RAM Replacement: 3 단계, 이미지 1/1
    • The right latch is spring loaded, hold the latch towards the center of the computer.
    • To remove the battery, pull the battery bar away from the computer.
  4. HP Pavilion 15-d017cl RAM Replacement, RAM: 4 단계, 이미지 1/2 HP Pavilion 15-d017cl RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Flip the laptop onto its back in order to have access to the back panel.
    • Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
  5. HP Pavilion 15-d017cl RAM Replacement: 5 단계, 이미지 1/2 HP Pavilion 15-d017cl RAM Replacement: 5 단계, 이미지 2/2
    • To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
    • This may require a good amount of strength to loosen the panel. As the opening tool is moving around the panel, clicking noises will be heard.
  6. HP Pavilion 15-d017cl RAM Replacement: 6 단계, 이미지 1/3 HP Pavilion 15-d017cl RAM Replacement: 6 단계, 이미지 2/3 HP Pavilion 15-d017cl RAM Replacement: 6 단계, 이미지 3/3
    • Using a spudger, press down on the silver latches that are holding the RAM in place. The RAM looks like a blue rectangle and has a size of about 1 x 2 inches. A slight click will be heard, and the RAM should pop out. You can then pull it away from the laptop.
    • Now that the old RAM has been removed, the new RAM can be inserted back into the laptop by pressing it gently into the place where the old RAM was.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alana Dawson
회원 가입일: 09/24/19
265 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 385
