주요 콘텐츠로 건너뛰기
HP Pavilion 15-d035dx Disk Drive Replacement
필요한 것
  1. HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx Disk Drive Replacement, Back Panel: 2 단계, 이미지 1개 중 1개
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  3. HP Pavilion 15-d035dx Disk Drive Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-d035dx Disk Drive Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-d035dx Disk Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  4. HP Pavilion 15-d035dx Disk Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
  5. HP Pavilion 15-d035dx Disk Drive Replacement, Disk Drive: 5 단계, 이미지 1개 중 1개
    • Once you have removed the panel there is one screw (2.5x6mm) that will need to be unscrewed.
  6. HP Pavilion 15-d035dx Disk Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-d035dx Disk Drive Replacement: 6 단계, 이미지 2개 중 2개
    • After unscrewing the back screw for the disc drive another 14 screws (2.5x6.0mm) will need to be removed.
  7. HP Pavilion 15-d035dx Disk Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Now flip the computer back to right side up.
    • Using the plastic opening tool from iFixit to pry open the top half of laptop case. Take off the top half.
  8. HP Pavilion 15-d035dx Disk Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-d035dx Disk Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Now seeing the inside of the laptop. Unscrew one more screw (2.0x3.0mm).
  9. HP Pavilion 15-d035dx Disk Drive Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion 15-d035dx Disk Drive Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion 15-d035dx Disk Drive Replacement: 9 단계, 이미지 3개 중 3개
    • Now you should be able slide the disk drive out to the side.
    • Do not pull up on the disk drive. This could damage the plug ins and/or the case that help holds it all together.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
John Atkins
회원 가입일: 09/25/17
273 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 29
전체 시간: 1,249
