주요 콘텐츠로 건너뛰기
HP Pavilion 15-d035dx Front Panel Replacement
필요한 것
  1. HP Pavilion 15-d035dx Front Panel Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 15-d035dx Front Panel Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 15-d035dx Front Panel Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx Front Panel Replacement, Front Panel: 2 단계, 이미지 1개 중 1개
    • Begin by laying the laptop on its backside with the bottom of the laptop facing you.
  3. HP Pavilion 15-d035dx Front Panel Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-d035dx Front Panel Replacement: 3 단계, 이미지 2개 중 2개
    • There will be 11, 2.5x3.0mm Philips head screws that you will need to locate.
    • Continue by unscrewing all of them using a 0 Phillips screwdriver.
  4. HP Pavilion 15-d035dx Front Panel Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-d035dx Front Panel Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-d035dx Front Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Take off the back panel by removing the 4.0x4.7mm Philips head screw.
    • Then using the opening tool, work around the edges to pull off the back panel.
    • It will take some force to get the back panel off.
  5. HP Pavilion 15-d035dx Front Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Now flip the computer right side up and open up the laptop.
    • You should be facing the screen and keyboard.
  6. HP Pavilion 15-d035dx Front Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Now using the opening tool remove the front panel from the back panel.
    • It should start to pop off, you will have to do this step around the entire computer.
    • It will give some resistance so take your time to ensure that nothing breaks.
  7. HP Pavilion 15-d035dx Front Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Once you have popped off the panel it should simply be able to lift off of the laptop.
    • Keep in mind that the keyboard is still connected to the motherboard. Simply lay the keyboard on top of the screen while you are completing future guides.
    • You can replace the front panel now.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
John Atkins
회원 가입일: 09/25/17
273 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 1,113
