주요 콘텐츠로 건너뛰기
HP Pavilion 15-e043cl RAM Replacement
필요한 것
  1. HP Pavilion 15-e043cl RAM Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion 15-e043cl RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the device over.
    • Slide the battery switch on the right half of the laptop.
    • Make sure the device is powered off, and that it is not connected to any power sources.
  2. HP Pavilion 15-e043cl RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-e043cl RAM Replacement: 2 단계, 이미지 2/2
    • Lift the battery up and out of the device by the inward-facing edge.
  3. HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: 3 단계, 이미지 1/3 HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: 3 단계, 이미지 2/3 HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: 3 단계, 이미지 3/3
    • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
    • The screw can not, and should not, be fully removed.
    • Slide the maintenance panel away from the battery compartment to release it.
  4. HP Pavilion 15-e043cl RAM Replacement, RAM: 4 단계, 이미지 1/2 HP Pavilion 15-e043cl RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Push the two silver arms away from the RAM card.
    • Pull the RAM card out of its slot.
결론
Cace Letendre
회원 가입일: 10/25/22
519 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G5
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 123
