주요 콘텐츠로 건너뛰기
HP Pavilion 15-eg0025nr Battery Replacement
필요한 것
  1. HP Pavilion 15-eg0025nr Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Unplug and turn off the laptop before removing the back panel
    • Flip over the computer so that the back panel is facing upwards.
    • Remove the two silver screws on the bottom of the laptop using a Phillips #00 screwdriver.
  2. HP Pavilion 15-eg0025nr Battery Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-eg0025nr Battery Replacement: 2 단계, 이미지 2/2
    • Peel up each end of the two gray rubber stoppers using your fingers or an opening pick.
    • This may be difficult if it is your first time removing them.
    • Remove the two black screws underneath the rubber stoppers with the Phillips #00 screwdriver
  3. HP Pavilion 15-eg0025nr Battery Replacement: 3 단계, 이미지 1/3 HP Pavilion 15-eg0025nr Battery Replacement: 3 단계, 이미지 2/3 HP Pavilion 15-eg0025nr Battery Replacement: 3 단계, 이미지 3/3
    • Slide the opening pick around the edges of the laptop where the chassis has a seam.
    • You will hear a clicking noise as you undo the clips of the chassis.
    • It may be easier to start with the four corners of the laptop, and then follow through with the sides.
  4. HP Pavilion 15-eg0025nr Battery Replacement: 4 단계, 이미지 1/1
    • Remove the back panel completely.
    • With the back panel removed, you can now access parts of the laptop such as the fan or the battery.
  5. HP Pavilion 15-eg0025nr Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Remove the five screws from the battery using a Phillips #00 screwdriver.
  6. HP Pavilion 15-eg0025nr Battery Replacement: 6 단계, 이미지 1/2 HP Pavilion 15-eg0025nr Battery Replacement: 6 단계, 이미지 2/2
    • Remove the battery from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Khin Sandar Win
회원 가입일: 09/06/22
216 평판
안내서 2개 작성하였습니다
University of Colorado Denver, Team 1-1, Campeau Fall 2022 University of Colorado Denver, Team 1-1, Campeau Fall 2022 회원
UCDENVER-CAMPEAU-F22S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 35
전체 시간: 762
