주요 콘텐츠로 건너뛰기
HP Pavilion 15-p Hard Drive Replacement
필요한 것
  1. HP Pavilion 15-p Hard Drive Replacement, Prepare the laptop: 1 단계, 이미지 1/3 HP Pavilion 15-p Hard Drive Replacement, Prepare the laptop: 1 단계, 이미지 2/3 HP Pavilion 15-p Hard Drive Replacement, Prepare the laptop: 1 단계, 이미지 3/3
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Hard Drive Replacement, Unlock the  battery: 2 단계, 이미지 1/3 HP Pavilion 15-p Hard Drive Replacement, Unlock the  battery: 2 단계, 이미지 2/3 HP Pavilion 15-p Hard Drive Replacement, Unlock the  battery: 2 단계, 이미지 3/3
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Hard Drive Replacement, Remove the battery: 3 단계, 이미지 1/2 HP Pavilion 15-p Hard Drive Replacement, Remove the battery: 3 단계, 이미지 2/2
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Hard Drive Replacement, Remove the optical drive: 4 단계, 이미지 1/3 HP Pavilion 15-p Hard Drive Replacement, Remove the optical drive: 4 단계, 이미지 2/3 HP Pavilion 15-p Hard Drive Replacement, Remove the optical drive: 4 단계, 이미지 3/3
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
  5. HP Pavilion 15-p Hard Drive Replacement, Remove the screws under the optical drive: 5 단계, 이미지 1/1
    • The system used in the guide only came with one screw. If yours came with three, sort accordingly.
    • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
  6. HP Pavilion 15-p Hard Drive Replacement, Remove the bottom screws: 6 단계, 이미지 1/1
    • Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • This screw is hidden by a sticker. If lost/damaged, it is cosmetic.
    • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
  7. HP Pavilion 15-p Hard Drive Replacement, Remove the hinge caps: 7 단계, 이미지 1/3 HP Pavilion 15-p Hard Drive Replacement, Remove the hinge caps: 7 단계, 이미지 2/3 HP Pavilion 15-p Hard Drive Replacement, Remove the hinge caps: 7 단계, 이미지 3/3
    • If you choose to reuse the original pads, stick them to the hinge caps to preserve the adhesive.
    • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
    • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
  8. HP Pavilion 15-p Hard Drive Replacement, Remove the palmrest: 8 단계, 이미지 1/3 HP Pavilion 15-p Hard Drive Replacement, Remove the palmrest: 8 단계, 이미지 2/3 HP Pavilion 15-p Hard Drive Replacement, Remove the palmrest: 8 단계, 이미지 3/3
    • Do not fully remove the palmrest - the power button is still connected to the motherboard.
    • If you are having trouble removing the palmrest, try using a guitar pick.
    • Run a plastic tool around all 3 sides of the palmrest. Once they are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up and disconnect the cables.
    • Once the keyboard and trackpad are disconnected, the palmrest can be lifted up. In some cases, further prying may be needed.
  9. HP Pavilion 15-p Hard Drive Replacement, Disconnect the power button: 9 단계, 이미지 1/3 HP Pavilion 15-p Hard Drive Replacement, Disconnect the power button: 9 단계, 이미지 2/3 HP Pavilion 15-p Hard Drive Replacement, Disconnect the power button: 9 단계, 이미지 3/3
    • With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
  10. HP Pavilion 15-p Hard Drive Replacement, Disconnect the flat flex: 10 단계, 이미지 1/3 HP Pavilion 15-p Hard Drive Replacement, Disconnect the flat flex: 10 단계, 이미지 2/3 HP Pavilion 15-p Hard Drive Replacement, Disconnect the flat flex: 10 단계, 이미지 3/3
    • If this guide is used as a prerequisite, the hard drive may not need to be removed.
    • The I/O daugherboard can be removed if it is in the way.
    • Disconnect the flat flex cable over the hard drive. To do this, lift the black locking tab up and remove the cable from the ZIF socket.
    • To remove the hard drive, tilt it forward starting with the SATA interface. Once it is removed, set it aside as shown.
    • Disconnnect the drive cable. Wiggle the cable off until it is released. Do not forcefully remove the cable. Unserviced "virgin" systems may require more force.
  11. HP Pavilion 15-p Hard Drive Replacement, Remove the drive bumpers: 11 단계, 이미지 1/2 HP Pavilion 15-p Hard Drive Replacement, Remove the drive bumpers: 11 단계, 이미지 2/2
    • If your hard drive has a plastic sticker over the PCB and an SSD is installed, put this in the chassis in case a traditional hard drive is installed later.
    • If your drive has a plastic sticker over the drive PCB, this MUST be transferred to the new drive.
    • Remove the drive bumpers from the old drive. Transfer these to the new hard drive.
결론
Once tested and reassembled, you will need to install an operating system. Install whatever OS you like.
다른 61명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
86,329 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
320 회원들
안내서 1,356개 작성하였습니다
댓글 35개
Some hp pavilions you need to detach the keyboard first, then, and only then, can you access the screws that hold the palmrest!
lifeat46hol - 답글
This isn't the case on the P series. The keyboard is welded in with plastic so the top piece and keyboard is a singular component.
Nick -
Thanks, Nick. Great guide, took me about 20 mins to get this done.
Maarten Merken - 답글
That’s good to know. I said 2 hours to cover for users who will take a little longer to complete the repair. The difficulty also reflects on that.
Nick -
Dear Nick,
Thank you for the info. My Wife’s laptop is a slightly different version but I was able to install a SSD today. What a nightmare! I’ve never known a laptop to be so difficult to upgrade.
Cheers!
Andy
NoOnions - 답글
댓글 쓰기
조회 통계:
24 시간 전: 32
7일 전: 218
30일 전: 2,375
전체 시간: 155,521
