주요 콘텐츠로 건너뛰기
HP Pavilion 15-p Optical drive Replacement
필요한 것
  1. HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: 1 단계, 이미지 1/3 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: 1 단계, 이미지 2/3 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: 1 단계, 이미지 3/3
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: 2 단계, 이미지 1/3 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: 2 단계, 이미지 2/3 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: 2 단계, 이미지 3/3
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Optical drive Replacement, Remove the battery: 3 단계, 이미지 1/2 HP Pavilion 15-p Optical drive Replacement, Remove the battery: 3 단계, 이미지 2/2
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Optical drive Replacement, Remove the screw: 4 단계, 이미지 1/3 HP Pavilion 15-p Optical drive Replacement, Remove the screw: 4 단계, 이미지 2/3 HP Pavilion 15-p Optical drive Replacement, Remove the screw: 4 단계, 이미지 3/3
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once this screw is removed.
  5. HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: 5 단계, 이미지 1/2 HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: 5 단계, 이미지 2/2
    • Remove the screws holding the optical drive bracket onto the drive. To do this, use a Phillips #0 screwdriver.
  6. HP Pavilion 15-p Optical drive Replacement, Faceplate removal: 6 단계, 이미지 1/3 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: 6 단계, 이미지 2/3 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: 6 단계, 이미지 3/3
    • Be careful not to break any clips. The faceplate will still be usable, but will be loose fitting.
    • To remove the faceplate, open the optical drive with a paper clip. Once the tray is released, use a flat tool to release the visible clip on the faceplate. Once done, the faceplate should come off.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
86,329 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
320 회원들
안내서 1,356개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 19
30일 전: 73
전체 시간: 6,859
