주요 콘텐츠로 건너뛰기
HP Pavilion 15-p043cl Repair I/O Replacement
필요한 것
  1. HP Pavilion 15-p043cl Repair I/O Replacement, I/O: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement, I/O: 1 단계, 이미지 2개 중 2개
    • Flip the laptop over, showing the backplate face up
  2. HP Pavilion 15-p043cl Repair I/O Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair I/O Replacement: 2 단계, 이미지 3개 중 3개
    • Use your #1 Phillips-head screwdriver to remove all the 8 mm screws
    • Make sure to put the screws in a magnetic holder or another safe place
  3. HP Pavilion 15-p043cl Repair I/O Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair I/O Replacement: 3 단계, 이미지 3개 중 3개
    • After removing all the 8 mm screws, start to pry open the optical drive using your finders or a wedge.
  4. HP Pavilion 15-p043cl Repair I/O Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement: 4 단계, 이미지 2개 중 2개
    • Pull out the battery by positioning the switch with the lock symbol on unlock and pushing the switch with the battery towards the center of the laptop.
  5. HP Pavilion 15-p043cl Repair I/O Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair I/O Replacement: 5 단계, 이미지 3개 중 3개
    • Use an opening pick or wedge to start to pry open the laptop keyboard cover.
    • Follow along the perimeter and separate the cover from the laptop.
  6. HP Pavilion 15-p043cl Repair I/O Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair I/O Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully remove the keyboard assembly.
    • Make sure to unplug the 3 ribbon cables connecting the keyboard, mousepad and power button to the motherboard
  7. HP Pavilion 15-p043cl Repair I/O Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the I/O ports, and remove the bottom most ribbon cable.
  8. HP Pavilion 15-p043cl Repair I/O Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Repair I/O Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Repair I/O Replacement: 8 단계, 이미지 3개 중 3개
    • Locate and remove the screw holding the I/O board in.
    • Once the screw has been removed lift the I/O board straight up and out of the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Teague Mendez
회원 가입일: 10/01/23
692 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 19
전체 시간: 145
