주요 콘텐츠로 건너뛰기
HP Pavilion 15-p043cl Wi-Fi Card Replacement
필요한 것
  1. HP Pavilion 15-p043cl Wi-Fi Card Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 2개
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 3개
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
  4. HP Pavilion 15-p043cl Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 3개 중 3개
    • Flip laptop to make the backplate face up.
    • Use a #1 Phillips-head screwdriver to unscrew all eleven 8 mm bottom case screws.
  5. HP Pavilion 15-p043cl Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 2개
    • Pull out the battery by positioning the switch with the lock symbol on unlock and pushing the switch with the battery towards the center of the laptop
  6. HP Pavilion 15-p043cl Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 3개
    • Flip over the laptop so the HP symbol is facing up.
    • Open the lid of the laptop.
    • Using the spudger, pry between the case and keyboard/mousepad area.
  7. HP Pavilion 15-p043cl Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the keyboard area.
    • Make sure to unplug the 3 ribbon cables connecting the keyboard, mousepad and power button to the motherboard.
  8. HP Pavilion 15-p043cl Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-p043cl Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 3개
    • Unplug the black and white wires from the Wi-Fi card.
    • Unscrew the 4 mm screw holding the Wi-Fi card in place.
    • Gently pull up and away from the motherboard to pop out the card.
결론
작성자
2다른 기여자 명과 함께
Teague Mendez
회원 가입일: 10/01/23
692 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 215
